vcMaterialProperty
A property that holds a reference to a vcMaterial.
Parent: vcProperty
| AllowedValues | vcList | R | Gets the list of all available materials. |
| Type | vcPropertyType | R | Gets the property type. |
| Value | vcMaterial | RW | Gets or sets the property's value. |
| waitFor | object | vcMaterial OR None value, Optional Keyword[waitTrigger = Boolean] | Blocks script execution until vcProperty.Value is equal to the "value".See moreThis function returns an awaitable task. It must be awaited. Parameters: value (object): Value that is used for comparison. When the value is equal to vcProperty.Value, the task completes. Optional: waitTrigger (boolean): False by default. When waitTrigger is True, the task will wait for the value to change first, before comparing it against "value". Otherwise, the comparison is done immediately and when the values match, the task will complete without blocking the script. Returns: Awaitable[List]: The task instance. When awaited, returns a list of event arguments that the event has been triggered with. |
| waitForNot | object | vcMaterial OR None value, Optional Keyword[waitTrigger = Boolean] | Blocks script execution until vcProperty.Value is not equal to the "value".See moreThis function returns an awaitable task. It must be awaited. Parameters: value (object): Value that is used for comparison. When the value is not equal to vcProperty.Value, the task completes. Optional: waitTrigger (boolean): False by default. When waitTrigger is True, the task will wait for the value to change first, before comparing it against "value". Otherwise, the comparison is done immediately and when the values do not match, the task will complete without blocking the script. Returns: Awaitable[List]: The task instance. When awaited, returns a list of event arguments that the event has been triggered with. |
